Well, the fly in the ointment is having to use antennaweb. When placing the receive location at the same spot I use in TVFool, antennaweb returns no stations, which is definitely not the case. If two of us agree on a recommendation, you can pretty much rely on it, so go with the 7696.
If you compare the 7696 with the 7697 at a site like solidsignal.com, you'll find theat you will spend about $17 more for only a modest improvement in some of the spectrum that you don't need.
