Tv antennas and Tv reception
To prove out the reception. Install a Known To Be Good matching transformer (balun) to the antenna and a Known To Be Good long length of coax connected to the Known To Be Good matching transformer and run the Known To Be Good long coax through a open door or window Direct to the Tv. The Tv Must scan for the Digital Broadcast Tv Channels sometimes named the 'Antenna Channels" or 'Air Channels' in the Tv menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna. . Do Not scan for cable Tv channels.
