Tv antennas and Tv reception
For the reception of the Tv stations/channels to the south , combine the CS4 with a C5 antenna and aim both at about 181 degree magnetic compass. The C5 will be on the bottom and the CS4 on top.
The C5 comes with a UVSJ UHF/VHF Separator/Joiner to connect both the CS4 and C5 together.
If you decide to receive the south Tv stations then the HD7698P antenna system then the CS4/C5 antenna system WILL NOT be combined on to one coax.
The north north/west antenna system and the south antenna system WILL HAVE and WILL BE Separate Systems and coax all the way to the Tv location and be connected to a Radio Shack # 15-1968 A/B remote control antenna switch.
The output of the A/B switch will connect to the Tv.
After you think all this over for awhile you will most likely say , I do not require the south Tv stations , so what do I do with the CS4 antenna??
There is the garage sale.
In the future for your friends antenna setup , Use the Exact address to make the tvfoll radar report and make the antenna height 25 feet. If your friend has the same reception as your location then it will be HD7698P / CPA-19 preamp for the north/north west Tv stations , and a HD7698P with no preamp for the south Tv stations.
