Tv antennas and Tv reception
Having antenna higher improves signal strength. ( getting the antenna higher clearing trees improves signal strength). For Tv reception Using a Large antenna Collects More Signal , using a small antenna collects less signal. For the Correct large antenna recommendation , make 2 more tvfool radar reports at 25 feet , 35 feet . Another way to make tvfool radar report is go to the tvfool home page and go to >>Start MAPS<< , move the pointer to your location and put in the antenna height , select Pending Applications Included and click on make radar map.
