Tv antennas and Tv reception
No , No , No and No Do Not connect cable and OTA onto one coax. Run separate coax for OTA and separate coax for cable. Many of the channels that are OTA , Cable also use on the cable system , mixing the two will not produce good results. . Satellite uses different frequencies so OTA and Satellite can be on the same coax , however for the final word you will need to get with satellite system installer.
