Tv antennas and Tv reception
If the pointer for latitude and longitude was centered on your house then thats Ok. It is also Ok to use your Exact address. If this tvfool radar map is correct and the antenna is going to be 12 feet above ground in the attic then you will receive only one Tv station , CIHF-DT 44. (and thats if no trees block the signal) If you will like to receive more then one Tv station , like 2 , 3 , 4 , 5 , or perhaps 6 Tv stations. Then make three more tvfool radar reports at , 25 feet , 35 feet and 45 feet. The antenna/s Will Be outside of the attic , above the roof or on some other structure that will get the antenna/s Up High.
