Tv antennas and Tv reception
This is a ridiculous tit for tat. I am getting as close to the truth as possible. KESD 8 Will Be Received by the HD7084P antenna. You are in fact receiving KDLO 3 with the indoor antenna , If as in -> IF <- KDLO 3 is not received with the HD7084P antenna and you will like to receive KDLO 3 then install a Radio Shack # 15-1968 remote control A/B antenna switch to switch between the HD7084P and the indoor antenna. And -> IF <- KABY 9 and K36DK 32 are not received by the HD7084P antenna and you will like to receive them then install a antenna rotor. Antenna rotors Are Not channel surfing friendly , must wait for the antenna to rotate. And as for KDSD-Tv 17 PBS and KWSF-LP 17 ?? and KSAX-DT 42 ABC that Signals Unlimited tossed in there they Will Not be received they are far to weak to receive with any antenna at your location. Signals Unlimited are you going to do this when ever you get the chance?? Or sometimes to stir the situations up??
