Tv antennas and Tv reception
The Tv channels that are transmitted and received here in the USA and Canada are , VHF low band channels 2 thru 6 , VHF high band channels 7 thru 13 , UHF channels 14 thru 51. Your location has channels in All 3 bands , KDLO channel 3 , KESD channel 8 , KABY channel 9 , KELO channel 11 , KSFY channel 13 , KSMW channel 15 , KDLT channel 47 , K50DG channel 50 . The HD7084P is designed to receive the Tv stations/channels Of All 3 Tv Bands. The C4 is designed to receive one Tv band UHF 14 thru 51. Like I said , the Tv stations/channels to the south/east are VERY WEAK and a big All channel antenna collects more signal then a small antenna. But then prove it for your self , install the C4. Do not install a antenna rotator at this time , Like I said , I believe the Stronger Tv stations/channels to the north/west will be received through the back side of the HD7084P antenna.
