Old 24-Apr-2012, 1:49 AM   #5
signals unlimited
The Winegard antenna 7698P is very directional (a good thing). If you use this antenna you will obtain best results with a rotor. I recomend the Aspen Eagel. Easy to install. Uses the signal coax to operate. Very accurate and reliable. buy at www.solidsignals.com
