Thread: Losing my mind!
Old 22-Apr-2012, 11:41 PM   #2
Electron
Tv antennas and Tv reception
A simple reception situation. With a simple modification to a tv antenna. Remove the reflector screen from a Antennas Direct , Clear Stream 2 Complete , CS2v , UHF/VHF antenna and the CS2V will receive at the front of the antenna and back of the antenna. The flat side of the loops and rods are what is directed at the Tv stations. Aim the antenna at 140 or 320 degree magnetic compass and the antenna will receive the Tv stations to the , west , north/west , south , south/east. No rotator is required because the CS2v receives the Tv stations in both directions at the same time. http://www.antennasdirect.com. http://www.antennasdirect.com/store/...VHF-Combo.html . The Tv stations/channels are Very Strong of signal strength , no amplifier is requried for 1 , 2 , 3 ,4 tv's connected. For one tv connected use no splitter , For 2 Tv's connected use a 2 way splitter , For 3 Tv's connected use a 3 way splitter , For 4 Tv's connected use a 4 way splitter. You said something about a much longer cable run , how long do you estimate the run is??
