Tv antennas and Tv reception
Make the recommended adjustments with the HBU55 and test hook up connections. And report here with the reception. WFLI-DT 42 The CW is very weak , how is the reception of WFLI ??
The 2 antennas HBU55 and HD7698P can not be connected together on to one coax. The rotor you have can be used to 'fine tune' the reception.
Do the test adjustments to the HBU55 UHF reflector and balun and coax and one tv and retun with a report.
