Old 9-Aug-2010, 1:05 PM   #4
SWHouston
An Old Member
SWHouston's Avatar
Attic Mounting an Antenna
Greetings Quinn,
I have an Attic Mount, foil backed Plyboard included, which I am very satisfied with. I'd try putting your Antenna in your attic. However, it's a good idea to get an Antenna which is a bit stronger, to compensate for shooting through the materials.
Your chart looks good, but you only need a "Modified" Range (Ch 7-69) Antenna, to get the job done.
There are several Antennas which should do the job well enough like the....
AntennaCraft HBU-22 or
Antennas Direct V-10 or
Channel Master 2016 or
Terrestrial Digital SR-15 or
Winegard HD7694P
There are probably several others (some BowTie's included) which would work also, but, I selected the "Yagi" type, because of it's reliability in the VHFhi range.
When mounting in an attic, take a look at the following Drawings, which may give you some ideas about the mount.
Attic Mount for TV Antenna
Hanging Mount for Antenna
Have a good Day !
S.W.
Good Golf, good OTA/HDTV and anything else that makes you HAPPY
OTA: AntennaCraft/RS VU-90XR (Attic Mt). DTVPal DVR, Sony RDR-VXD655, WinTV HVR-850-1200.
D/A: Samsung H260F, Winegard RC-DT09A, DTVPal Plus.
Typical OTA Reception Houston TX 77033
SWHouston is offline   Reply With Quote
