If you don't mind a rather large antenna on your roof, the HD7082 surely will deliver all of the UHF and VHF channels to your South West and work on any Low VHF that may show up in future re-alighnment of spectrum or new LP station that could come on line.
If you have an attic and a roof that is not metal or tile, you may want to look at a simple installation of an RCA ANT751. No amplifier should be needed, however if you miss any desired channels you could add a low gain pre-amplifier such as the Channel Master 7778 (16 db ) UHF and VHF. This system should deliver all of the channels from the 240 degree magnetic direction with enough signal left over to run up to four sets, provided the cable runs are less than 50 feet in length.
