If the building is wood frame with wood or vinyl siding and standard composition singles. Then a Terk HDTVi Non Amplified antenna aimed at about 240 degree magnetic compass will receive the Real UHF and VHF digital Tv channels. Here is how to aim indoor antennas ,
http://www.kyes.com/antenna/pointing/pointing.html. If the building is , concrete , concrete block , cinder block , bricks from ground to roof , big rocks for walls , earth walls , metal framing , metal siding , stucko Wire , metal backed insulation , solar panels , then the reception with a indoor antenna will be reduced or blocked. Put the antenna in a window that has no metal screen toward the south west for better reception.
Based on the Current Plus Pending Applications Included Digital Tv Stations/Channels receive all the green and yellow reception zone stations/channels. Install a Winegard Hd7082P antenna above the roof aimed at about 240 degree magnetic compass. Here is how to aim antennas ,
http://www.kyes.com/antenna/pointing/pointing.html. Here are some strong and sturdy antenna mounts ,
http://www.ronard.com/909911.html ,
http://www.ronard.com/34424560.html /
http://www.ronard.com/ychim.html ,
http://www.ronard.com . Buy the ronard mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard. Here are some places to buy antennas and etc. ,
http://www.solidsignal.com ,
http://www.winegarddirect.com ,
http://www.amazon.com. The HD7082P antenna will supply signal to , 1 , 2 , 3 , or 4 Tv's with no amplifier.
The Tv/s Must Scan for the Digital Broadcast Tv Channels sometimes named the 'Air Channels" or 'Antenna Channels' because the tv transmissions travel through the air from the transmitting antenna to your receiving antenna. DO NOT scan for cable Tv channels.
