Old 20-Apr-2012, 10:43 PM   #13
OldStump
When you punch in "4", "-", "2" on the remote here in Seattle, the TV has to look in the table created during the channel scan. It finds an entry for virtual channel 4-2 and sees that the real channel is UHF CH-38. The tuner is then set to real channel 38 and the data associated with the desired program can be filtered out of the rest of the data and set to the video and audio decoding process.
Many sets will not tune or display a channel without performing a channel scan... to create the table data that is used to control the tuner.
Some of my sets will accept manual entry of the real channel number.
Do you know how if I can find out if my Samsung UN55B7000 might allow direct tuning without a scan? I've looked around, but that's not mentioned in the manual.
I'm suspicious that I may miss out on weak signals that does not appear at the precise time I scan.
That might explain why last night I could not get channel 8-1, which I can get today, while the situation is reversed for channel 5-1. Manual tuning might allow me to add entries to the table without removing existing entries.
@David Loudin: You and GUM are an amazing source of fascinating information that 90% of the population wouldn't need or care about - just the kind of stuff I like!
If you have more, keep it coming.
OldStump is offline   Reply With Quote
