Old 19-Apr-2012, 11:42 PM   #1
MidTnMan
Need Equipment Recommendations for an Attic Install
Hi. I have a large attic spot where I would like to place an antenna for HD reception. My roof is of the usual plywood/shingle variety. Elevation to the top on the antenna would not exceed 15'. Here is my report:
http://www.tvfool.com/?option=com_wr...7fcfb70a483a33
I'm primarily concerned with receiving a high quality signal from the major networks. ABC, CBS, FOX, NBC, and PBS. Unforunately, the best signal for CBS comes from RF5. That leaves me with a dilemma trying to decide which antenna would cover all the bases, including the low-vhf requirement for CBS. According to the report, CBS is also available with a weaker signal at RF50.
I'm also looking to avoid a solution that would require a rotor. I thought the Clearstream2-V with a CPA-19 preamp might be an option, but I could definitely use some knowledgeable opinions/suggestions.
I will likely want to split the signal for 3 TVs at some point, if that is a factor.
Thanks in advance.
MidTnMan is offline   Reply With Quote
