Based on your TV Fool report a Terk HDTVi indoor antenna would be worth your consideration if you were connecting a single set.
For even better reception reliability, I'd suggest a roof or wall mounted RCA ANT-751 or better yet, a roof mounted Winegard HD7010. The strong signal levels would be sufficient to drive a passive 4-way splitter and the coax runs in a single family home... no amplifier needed.
In either case, begin by aiming at about 160° compass, then fine tune by moving the antenna left and right to find the most reliable signal quality.
