Tv antennas and Tv reception
You can turn the HD8200U by hand or can or use a rotor , RCA VH126N rotor . There is also the Eagle Aspen rotor ROTR100 , (if you use the ROTR100 then install solid copper center wire quad shield coax between the inside power unit and outside rotor for maximum power transfer and stable operation) The Channel Master CM9521A rotor is out stock at Channel Master due to Quality control problems. I do not recommend the channel master rotor of old stock some where else. None of the general consumer antenna rotors are rated to handle this big antenna over a long period time. There are Ham radio antenna rotors that will easly handle the HD8200U antenna. However the cost is More and None of the Ham radio rotors have remote control that I know of. You can do research and ask questions at the Ham radio and Ham rotor web sites. The rotors are rated by , weight , size and wind load of the antenna. I will return with some makes and model numbers.
