Old 19-Apr-2012, 6:55 PM   #7
Tv antennas and Tv reception
As a test and for the reception of the other Tv stations/channels at about , 164 , 232 , 276 , degrees magnetic compass. Install a Winegard HD8200U antenna Without a preamp at first and can add a Antennas Direct CPA-19 preamp as part of the experiment of reception. The HD8200U antenna will be mounted above the roof on a Separate mount from the HD7080P antenna. As part of the experiment the HD8200U can be a few feet or higher above the roof mounted on a Strong And Sturdy antenna mount such as these , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com/engineered-rot...ount-3324.html , http://www.ronard.com . Buy the ronard antenna mounts at solidsignal by typing the word ronard in the soildsignal search box or buy from ronard. Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.antennasdirect.com , http://www.amazon.com. I will return with more information shortly.
