Tv antennas and Tv reception
The answer is Yes , However , the signal strength at your location for most of Tv stations is so Strong that the signal strength meter will likely read full strength no matter direction the antenna is aimed. HOWEVER using the Pending Applications Included as a reference there are some weak Tv stations/channels in the red reception zone that you can use to test the reception by turning the antenna , KTBV , KNBC , KVEA.
