Old 19-Apr-2012, 5:31 PM   #14
MisterMe
Originally Posted by tavish28 View Post
After taking some measurements I played around with the Leaf last night moving it to the south west most corner of the apartment even though there's no window there. I was surprised that all the main channels came in well, except 11.
I could probably live with this the way it is now, but would something like the Terk HDTVa or HDTVi mentioned earlier work better than the Leaf? The HD1080 wouldn't fit in this corner and HDX1000 is a bit expensive for me.
You are not receiving WPIX (RF11) because it broadcasts in the VHF band whereas the Leaf is primarily a UHF antenna. signals unlimited told you that it relies on the coax as the receiving element for VHF.
You have received several recommendations. Each of the recommended antennas will have better reception than the Leaf. You did not receive a recommendation for the Terk HDTVa. This is an amplified antenna. With so many strong signals available to you, the aggregate power received by the antenna may saturate the amplifier making things worse.
MisterMe is offline   Reply With Quote
