Old 19-Apr-2012, 3:56 AM   #11
I would certainly try this install without a rotator... I would suggest you consider using a high input preamp at the antenna. Though the CM34XX series DAs are good (I own a few), a mast head preamp such as an Antennas Direct CPA-19 has lower noise and it can be placed ahead of all the down-lead loss which will further improve your signal quality as compared to the DA located at the end of the down-lead.
