Old 19-Apr-2012, 3:22 AM   #2
TV antenna mast is commonly swedged so that the end of one section fits inside the end of the next. Example:http://www.channelmaster.com/Antenna..._1810_s/87.htm This type mast does not need to be clamped or bolted when supported by guys which is the common support method used with stacked sections of this type.
A guy wire clamp is usually used at each mast joint and about 2/3rds up the top section. http://www.summitsource.com/guy-wire...15-p-7190.html
