Thread: New to OTA
Old 18-Apr-2012, 11:57 PM   #9
Tv antennas and Tv reception
You can play the game of 'what if' at tvfool. Go to the >>Start MAPS<< part of tvfool on the home page. put in your address , when the map comes up , you move the pointer to other locations and see what reception is like there. Having the antenna on hills (higher ground elevation) is usually better. A good starting antenna height is 25 feet because 25 feet is about the height of a antenna mounted above the roof. Also click on Pending Applications Included that way you get the current and pending stations. The game is to get the Tv stations signal strengths in to the , red , yellow , green , reception zones. The gray reception zone is no good. American Tv stations call signs start with a W or K.
