Old 18-Apr-2012, 5:50 PM   #4
MisterMe
Originally Posted by tavish28 View Post
Any recommendation on what rabbit-ears to get? Also, is the suggestion of the diplexer mean I should be using two antennas?
You need a diplexer only if you are combining separate VHF and UHF antennas. With the signals available to you, there is no need for such a complicated setup. I would recommend a Terk HDTVi. This is a non-amplified VHF/UHF antenna. Place it in a window with a southern view and point your antenna at about 230° magnetic or about 20° west of due south. You may have trouble with WTBY (RF27) and WRNN (RF48) because your apartment building blocks their signals. Everything else in the green should come in strongly.
