KFFS shows is listed as a class A. That commits them to be on air for all but short periods for maintenance or emergency repairs. The also have a construction permit for another channel 36. Not sure what that is. I would call the station for an explaination before going into any equipment changes or additions. If all is normal with their signal, try a double rescan on your set with the antenna in their direction. Disconnect the coax from your set, run a scan, reconnect the coax to your set, scan once more.
