Old 18-Apr-2012, 5:05 AM   #4
jbsb
Hi,
Thanks for the great info. I have two coax cables that run from the TV to the Satellite dish that is already up there so that should not be a problem I think I would need to move to the other end of the roof to get a more clear shot at pointing the antenna's correctly without obstruction from trees. If I add on another 30ft of RG6 coax would I still be ok with the setup you suggested or would I need an amplifier or something to help with the added length of cable?
Sorry I'm new to this so I'm assuming the radar plot is the same report I did previously.
Here is 45ft
http://www.tvfool.com/?option=com_wr...d5bc1900eb102d
and 60ft
http://www.tvfool.com/?option=com_wr...d5bc79032651a9
Appreciate the help,
-Jon
jbsb is offline   Reply With Quote
