Old 13-Jan-2010, 1:40 AM   #10
mtownsend
Originally Posted by lray882 View Post
Channel 2 and 8 come in good but it and miss with the rest and no Channnel 5 at all.
Channel 5 is being broadcast from a different mountain peak (further away) than channels 2 and 8. Depending on exactly where you are, this might explain the difference in your ability to pick up these stations. A tvfool report of your exact location would help.
I think I would rather good for one antenna instead of two.
One antenna would certainly be easier to install. The best solution depends on what signals are available at your location. For fritzel67, about half his channels are coming from Nashville, and the other half are coming from Huntsville, hence the recommendation for two antennas.
If your location has a better view of Nashville stations, then you might be lucky enough to get everything you need with just one antenna.
