KTXL is one of your strongest signals among 17 very strong signals and 11 additional signals that are more than ample. In the Winegard HD7697P, you have a truly awesome antenna that should be able to pull-in every station listed in your TVFR plot. With as much signal as you are receiving, I seriously doubt that you need an amplifier.
Have you tested you antenna with an uninterrupted connection between your antenna balun and your TV? No amplifier, no splitter, no nothing? If you get good reception on one TV, then install a splitter and run cables to each TV from the splitter.
