Old 17-Apr-2012, 7:37 PM   #3
Electron
Tv antennas and Tv reception
This recommendation is based on the Current Plus Pending Applications Included for digital tv stations/channels in the tvfool radar report of 04-17-2012. A simple reception situation. Install a Winegard HD7696P antenna above the roof aimed at about 184 degree magnetic compass. Here is how to aim antennas , http://www.keys.com/antenna/pointing/pointing.html. Of the receivable Tv stations . The Tv stations/channels that will be received are , WSNL-LD channel 47 NBC , KHDS-LP channel 51 ABC and MeTv , KAAS-DT channel 17 FOX and the Cool Tv , KWCH-DT channel 19 CBS and Local Weather. K15CN channel 15 Trinity Broadcasting Network , KSCW-DT channel 12 The CW , KPTS-DT channel 8 PBS. Thats the Tv stations in the , green , yellow and the first station that is KPTS PBS in the red reception zone. These Tv stations are received With Out a antenna Rotor , Antenna rotors are Not friendly for channel surfing , must wait for the antenna to rotate and not every one will agree where the antenna is aimed. There are some other stations/channels that can be received with a , Large Antenna , a antenna rotor or second antenna. Here they are , A second PBS - KOOD-DT channel 16 , KDUC-DT channel 31 Spanish Univision and the rest in the red reception zone are duplicates of what you will be already receiving NBC and ABC. The tv stations/channels in the gray reception zone Will Not be received.
