Old 17-Apr-2012, 12:11 PM   #1
species8350
Receiving signals from two transmitters?
I have a loft aerial (Yagi or Antiference Rx 12: http://www.antiference.co.uk/yagi-rx
I get good reception from the forward direction, and there is another transmitter at about 90 degrees to the antenna from which I can receive weak signals. I would like to strengthen these weak signals, but not weaken the signals from the forward direction.
The aerial cannot be moved. Actually, it could be rotated somewhat, but I would reluctant to make this adjustment for fear of losing my main transmitter signals.
Can anyone suggest a modification to my current aerial that would improve the reception at 90 degrees, but have little effect on the forward direction? I have considered the option of two aerials, but I doubt if my inbuilt tuner would be able to cope. I use an iDTV.
The signals are UHF, and digital.
I believe that the aerial is wideband.
If it matters, I live in the UK.
Thanks
Ps. Where is TV Fool based?
species8350 is offline   Reply With Quote
