Old 17-Apr-2012, 4:39 AM   #2
Tv antennas and Tv reception
The multi position switch of the ANT121R makes for bad reception. Buy a TERK HDTVi Non Amplified antenna and aim the TERK HDTVi antenna at about 353 degree magnetic compass. (the direction of CFTO-DT 9). Here is how to aim indoor rods and loop type antennas , http://www.kyes.com/antenna/pointing/pointing.html. You can try pointing the ANT121R the same way. Maybe you will get lucky and find a switch position that receives most of the Tv stations. It usually helps reception to get indoor type antennas up high and it can also help reception to put a indoor type antenna in a window that faces the Tv transmitter. Pull the rods out and adjust the rods into a low vee shape. Do not have the rods straight up vertical.
