Partial improvement
I would like to say thank you to everyone who has commented on this issue. I did the "double rescan" two times in a row to be sure the old information was overwritten. The outcome was not 100% fixed but more like 75%. It still has the problem of 0db signal after channel cycling, but not nearly as often as before. So with this additional info, does it sound more like a TV component issue or should I wait for awhile to see if the station fixes settings which may be causing this issue? Thank you again for all of your help.
