Tv antennas and Tv reception
As Always and is Always explained. Range figures are generalizations. The real numbers are the NM(dB) , Pwr(dBm) , The ERP Effective Radeated Power of transmitter antenna the gain of the receiving antenna , height distance and more. The calculations are somewhat involved. In the past I have offered a easy way to do the figuring for a close good enough approximation. In the past this has brought on debates about this technical issue or that technical issue , it get's bogged down and does not help question asker. If you will like to get into it there is an explaination with all the numbers here at tvfool web site. The tv transmissions are strong at your location and will be received by the CS2V antenna.
