Old 16-Apr-2012, 9:25 PM   #5
Electron
Tv antennas and Tv reception
A simple and easy reception situation. For reception of the groups tv stations/channels to the , south west , north east , and east , install a Antennas Direct CS2V antenna with a Antennas Direct CPA-19 preamp above the roof aimed at about 238 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Remove the reflector screen from the CS2V and now the CS2V will receive the groups of tv stations/channels to the , south west , north east and east. The CS2V UHF/VHF antenna is a Very Strong and Sturdy antenna. I have one and it is Extra Strong and Sturdy. Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/ychim.html , http://www.ronard.com/34424560.html , http://www.ronard.com. Buy the mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard. Here are places to by antennas and etc. , http://www.antennasdirect.com , http://www.solidsignal.com , http://www.amazon.com
The CS2V is designed to receive the 2 VHF high band channels of , WYES-TV Digital Channel 11 PBS and WKFK-LD Digital Channel 13 with these digital main channel and digital sub channels , http://www.thistv.com , http://www.myretrotv.com , http://www.iontelevision.com. And the CS2V also receives the UHF channels at your location. You have both VHF and UHF channels and the CS2V receives them. The CS2V is in fact a UHF/VHF antenna.
. The Tv's Must Scan for the Digital Broadcast Tv Channels sometimes named the 'Antenna Channels' or 'Air Channels' in the Tv set up menu because the tv transmissions travel throught the air from the transmitting antenna to your receiving antenna. . DO NOT scan for cable tv channels.
