Old 16-Apr-2012, 4:52 PM   #6
Electron
Tv antennas and Tv reception
With the reflector screen removed the DB4e receives equeal at the front of the antenna and the back of the antenna. Aiming one side of the DB4e at 150 degree magnetic compass makes the other side 330 degree magnetic compass. Those are starting aim directions. As always a antenna is turned to the left and right to find the best reception. So one side of the antenna at 310 and the other side is 130 is the best aim directions. Is the Y5713 connected?? And what direction is the Y5713 aimed at ?? Using the tv stations call letters as listed in the tvfool radar report and the ones I listed for you , what UHF stations are having situations. And are WRUF-LD VHF low band channel 5 and WNBW-DT VHF high band channel 9 being received??
