Old 4-Aug-2010, 9:12 AM   #3
kb2fzq
When you get the antenna up, connect just ONE TV to the antenna coax downlead, and write down your signal strengths on all stations (use a single female to female f-connector coupler,get at Radio Shack)....then connect the splitter and check signal on all TV's....this will give you a baseline figure on what the actual strengths are in the event you loose stations once all 3 TV's are connected....this is not like cable where the signal is white hot coming into the TV's, as you add TV's, each TV might loose signal strength for certain stations...just be aware....
DE K2YI
Hudson Falls, N.Y.
http://www.tvfool.com/?option=com_wr...9fbebf10412194
kb2fzq is offline   Reply With Quote
