Old 4-Aug-2010, 6:24 AM   #4
John Candle
Reception
The antenna is the Winegard HD7082P and the 2 way splitter is the Winegard SP-2052. The most common types of tv antenna roof mounts are the Tri-Pod mount and the Chimney mount. If you are installing new coax cable , then RG-6 solid copper center conductor coax. Find at http://www.solidsignal.com . . Point the antenna at WDRL channel 24 , magnetic compass reading 327. Also notice the virtual channels and real channels , notice that WBRA virtual 15.1 is Real 3.1 . . . ROKU/NETFLIX is Great , over 12,000 Movies and Tv Shows for $10.00 a month
