Old 15-Apr-2012, 11:04 PM   #7
signals unlimited
I worked for a channel 10 and was faced with this exact problem hundreds of times. Tried many antennas, and the ones that worked the best were of the type that you are using. This still may work if you try adjusting the gain setting on your antenna. You can also try other locations and height. Radio Shack can provide you with an extension coax to accomidate that.
