Old 15-Apr-2012, 6:48 PM   #10
meridish
My opinion
Hi JD central,
I was searching the same way as you are for the right setup for me. I would suggest you this antenna. I know this does not show up in any comparison chart. But don't worry. You won't regret. It costs just around C$35. This performed even better than DB8. My DB8 is sitting idle now. Plus It is a VHF/UHF antenna
Item : 53-6165-1V make : Eagle star pro
HDTV Indoor/Outdoor
Passive Antenna (VHF improved)
Frequency Range VHF: 174-230 MHZ, UHF: 470-862 MHZ
Antenna Gain VHF: 30 dB, UHF: 36 dB
Impedance 75 Ohms
Noise Figure ≤ 3.5 dB
I am attaching its picture.
In my case I have installed this in my attic with kiztech - 200 preamp. It is facing 160 degree. I am getting all the channels which others are getting in my area. I am also getting CKVR (3.1) and CHCH on regular basis. Most of the people in my area have issues in locking them.
my tvfool is http://www.tvfool.com/?option=com_wr...3616e2d3ba0045
I don't think you will need a preamp in your situation. You will only need a good quality distribution amplifier depending upon how many TV sets you want to run. Please Don't take my suggestion lightly. Sometimes cheap products do perform well. We have used 4 of these in my friend circle. All of us are happy with its shape and performance.
Good luck
Harry
meridish is offline   Reply With Quote
