I agree. The problem is due to a station change. A double rescan may fix. First remove the coax from your set and scan. This will clear out old information. Then reconnect your coax and scan. If this does not fix the problem, report it to the stations engineering department. Sometimes their PCIP generator parameters are wrong and they may not be aware untill reported.
