Thread: FM from 07083
Old 13-Apr-2012, 8:22 PM   #3
OberGeiss
Thanks AD...I am using your 91XG (rooftop mast mount) pre-mplifiwd with your CPA-19. Great combo!
Can I tap into the 91XG, so to speak, with an FM trap or similar, and cable from there to supply my two receivers with FM signal. Would such a trap or FM filter be cabled between the antenna and the CPA-19 pre amp assembly?
I am assuming that the Yagi would operate as a directional antenna when mounted horizontally?
Thanks again.
David
OberGeiss is offline   Reply With Quote
