Old 13-Apr-2012, 7:54 PM   #3
Electron
Tv antennas and Tv reception
Your location has MANY easy to receive Tv stations/channels to the , north , south , east , west , If ANT751 antenna is mounted above the roof and aimed at about 180 degree magnetic compass. The ANT751 is not all that directional of a antenna and will receive the tv stations to the , north , south , east , west. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are some antenna mounts , http://www.ronard.com/900911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com. Buy the ronard mounts at solidsignal by typing the word ronard in the soildsignal search box or buy from ronard. Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com. Yes you can start with the antenna in the attic and then move the antenna to above the roof when you find out that about a 1/3 of the channels are not being received with the the antenna in the attic. Here is the Federal Law that says Yes you can install and use antennas above the roof. http://www.fcc.gov/guides/over-air-r...n-devices-rule. . How many Tv's are/will be connected??
