Thread: FM from 07083
Old 13-Apr-2012, 6:21 PM   #2
...because FM Fool isn't set up quite the same as TVFool which easily allows report sharing. FMFool doesn't do that.
The mentioned antenna appears to be a simple base-loaded monopole much like the simple whip antenna used on automobiles. If your car radio picks up stations while in your driveway, this antenna should perform comparably if tested in the same location. If installed up on the roof, it should perform about the same as if you parked your car up there. Maybe Santa can do some comparison testing next Christmas.
Use either RG6 (suggested) or RG59 (shorter runs).
