Old 13-Apr-2012, 4:13 PM   #5
signals unlimited
If the stations at 320 magnetic are the only stations you need, I would recommend an RCA ANT751, this will easily mount to your sat pole. With the signal levels from these stations, you should need on pre-amp, however you may need to place a dirtribution amplifier ahead of the splitter. You can ground your coax with a 75 ohm ground block (ESD) near the entry point using a ground rod and a 12 guage solid copper wire, or inside where you can mount the ESD and run the 12 guage to the ground buss in your service panel. The antenna, and ground block are available at www.solidsignals.com
