I'm concerned that swapping out the XG 91 for the HD7084P (pointed at 50 deg) might cause me to lose WLIW. Is combining an all VHF with my Yagi set up ill advised? Thank you!
Also, getting some occasional pixelation and drop out on WLIW...nothing substantial but wondering if I should still add an FM trap to my Yagi set up? In that the XG 91 is described as an UHF antenna only, would adding an FM trap serve a good purpose here?
Thanks,
David
