Old 12-Apr-2012, 10:58 PM   #4
Electron
Tv antennas and Tv reception
KFXB is a Very Strong signal. If that station is not being received then something is wrong some where. As a test , remove ALL of the amplifier , the outside part the inside part , the power supply , the power injector , the point is remove ALL. Run a known to be good coax from the antenna direct to one tv , no splitters , no couplers , scan for the Digital Broadcast Tv Channels , Do Not scan for cable tv channels.
