Hello Again, Just got my rotor and HD7698P antenna with a pre- amp installed as directed with the help of all you good folks. My problem now is I don't pick up any stations at all no matter what direction I aim my antenna. What could be wrong? How do I go about figuring out if I did something wrong? I put in a guy wire from the antenna to the house so that I could run the rotor cable and coax cable off the ground. I wrapped the coax and rotor wire around this guy wire and also put on plastic ties to secure it to the guy wire. Would this create a problem? Please help me!
Thanks Dave
