Old 11-Apr-2012, 6:38 PM   #4
Tower Guy
Originally Posted by PaulB View Post
Looking to make the cut from cable, and looking to install an antenna.
My suggestion would be a Winegard HD 1080. It's VHF pattern is backwards from the UHF pattern. WTNH on channel 10 is opposite directions from most of the UHF stations.
http://www.solidsignal.com/pview.asp...-%28HD-1080%29
http://www.winegard.com/kbase/upload/HD-1080.pdf
Reception of WCTX (the CW) may not be reliable. If that matters to you, add a cheap UHF only antenna (DB-2) aimed at WCTX and get an A/B switch.
