Tv antennas and Tv reception
Thank you for using the word hyperbole , Hi perb O lee. I was concerned that your view of the world and concepts was limited to 'the roof flying off'!. The 5 foot tripod is better , the antenna is up a little higher. The Ronard mounts are the highest quality. The tar pads that go under the feet will make the tripod leak proof of a long time. A helpful hint , feed the coax up through the mast pipe and out the top , now the coax will not whip in the wind and and no taping to the outside of the mast. You can buy cheaper mounts on the internet.
